公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
具有耳机放大器和独立 SE 和 BTL 输入的 2W 单声道、模拟输入 AB 类音频放大器
Audio input type Analog Input
Architecture Class-AB
Speaker channels (Max) Mono
Power stage supply (Max) (V) 5.5
Power stage supply (Min) (V) 2.5
Load (Min) (ohms) 4
Output power (W) 2
SNR (dB) 93
THD + N @ 1 kHz (%) 0.2
Iq (Typ) (mA) 4.2
Control interface Hardware
Closed/open loop Closed
Analog supply (Min) (V) 2.5
Analog supply (Max) (V) 5.5
PSRR (dB) 65
Operating temperature range (C) -40 to 85
  • Ideal for Notebook Computers, PDAs, and Other Small Portable Audio Devices
  • 2 W Into 4 From 5-V Supply
  • 0.6 W Into 4 From 3-V Supply
  • Stereo Headphone Drive
  • Separate Inputs for the Mono (BTL) Signal, and Stereo (SE) Left/Right Signals
  • Wide Power Supply Compatibility 2.5 V to 5.5 V
  • Low Supply Current
    • 4.2 mA Typical at 5 V
    • 3.6 mA Typical at 3 V
  • Shutdown Control ...1 uA Typical
  • Shutdown Pin Is TTL Compatible
  • –40°C to 85°C Operating Temperature Range
  • Space-Saving, Thermally-Enhanced MSOP Packaging
The TPA0213 is a 2-W mono bridge-tied-load (BTL) amplifier designed to drive speakers with as low as 4- speaker.
The gain of the input stage is set by the user-selected input resistor and a 50-k/RI in BTL mode.
The TPA0213 is available in the 10-pin thermally-enhanced MSOP package (DGQ) and operates over an ambient temperature range of ?40°C to 85°C.
