公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
具有逻辑低电平关断模式的 1.1W 单声道、模拟输入 AB 类音频放大器
Audio input type Analog Input
Architecture Class-AB
Speaker channels (Max) Mono
Power stage supply (Max) (V) 5.5
Power stage supply (Min) (V) 2
Load (Min) (ohms) 8
Output power (W) 2.3
THD + N @ 1 kHz (%) 0.25
Iq (Typ) (mA) 6.5
Control interface Hardware
Closed/open loop Open
Analog supply (Min) (V) 2
Analog supply (Max) (V) 5.5
PSRR (dB) 65
Operating temperature range (C) -40 to 85
  • Does Not Require Output Coupling Capacitors, Bootstrap Capacitors, Or Snubber Circuits
  • 10-pin VSSOP and 8-pin SOIC Packages
  • Unity-Gain Stable
  • External Gain Set
Key Specifications
  • THD+N at 1kHz for 1W Continuous Average Output Power into 8? 0.5% (max)
  • Output Power At 1kHz Into 8? with 10% THD+N 1.5 W (typ)
  • Shutdown Current 0.01μA (typ)
  • Supply Voltage Range 2.0V to 5.5 V
All trademarks are the property of their respective owners.
The LM4876 is a single 5V supply bridge-connected audio power amplifier capable of delivering 1.1W (typ) of continuous average power to an 8? load with 0.5% THD+N.
Like other audio amplifiers in the Boomer series, the LM4876 is designed specifically to provide high quality output power with a minimal amount of external components. The LM4876 does not require output coupling capacitors, bootstrap capacitors, or snubber networks. It is perfectly suited for low-power portable systems.
The LM4876 features an active low externally controlled, micro-power shutdown mode. Additionally, the LM4876 features an internal thermal shutdown protection mechanism. For PCB space efficiency, the LM4876 is available in VSSOP and SOIC surface mount packages.
The unity-gain stable LM4876's closed loop gain is set using external resistors.
