公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
具有直流音量控制和耳机放大器的 750mW、立体声、模拟输入、AB 类音频放大器
Audio input type Analog Input
Architecture Class-AB
Speaker channels (Max) Mono
Power stage supply (Max) (V) 5.5
Power stage supply (Min) (V) 2.7
Load (Min) (ohms) 8
Output power (W) 1
THD + N @ 1 kHz (%) 0.6
Iq (Typ) (mA) 3.5
Control interface Hardware
Closed/open loop Open
Analog supply (Min) (V) 2.7
Analog supply (Max) (V) 5.5
PSRR (dB) 50
Operating temperature range (C) -40 to 85
  • DC Voltage Volume Control
  • Headphone Amplifier Mode
  • “Click and Pop” Suppression
  • Shutdown Control When Volume Control Pin Is Low
  • Thermal Shutdown Protection
Key Specifications
  • PO at 1.0% THD+N Into 8? SOIC, Micro SMD 750 mW (typ)
  • PO at 10% THD+N Into 8? SOIC, Micro SMD 1W (typ)
  • Shutdown Current 0.7μA(typ)
  • Supply Voltage Range 2.7V to 5.5 V
All trademarks are the property of their respective owners.
The LM4865 is a mono bridged audio power amplifier with DC voltage volume control. The LM4865 is capable of delivering 750mW of continuous average power into an 8? load with less than 1% THD when powered by a 5V power supply. Switching between bridged speaker mode and headphone (single ended) mode is accomplished using the headphone sense pin. To conserve power in portable applications, the LM4865's micropower shutdown mode (IQ = 0.7μA, typ) is activated when less than 300mV is applied to the DC Vol/SD pin.
Boomer audio power amplifiers are designed specifically to provide high power audio output while maintaining high fidelity. They require few external components and operate on low supply voltages.
