公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  196粉丝
--- 产品详情 ---
11W 立体声、9V 至 32V 电源电压、模拟输入 AB 类音频放大器
Audio input type Analog Input
Architecture Class-AB
Speaker channels (Max) Stereo
Power stage supply (Max) (V) 16
Power stage supply (Min) (V) 9.6
Load (Min) (ohms) 4
Output power (W) 11
THD + N @ 1 kHz (%) 0.08
Iq (Typ) (mA) 5.25
Control interface Hardware
Closed/open loop Closed
Analog supply (Min) (V) 9.6
Analog supply (Max) (V) 16
PSRR (dB) 50
Operating temperature range (C) 0 to 70
  • Drives 4? and 8? Loads
  • Internal Gain Resistors (AV = 34 dB)
  • Minimum External Component Requirement
  • Single Supply Operation
  • Internal Current Limiting
  • Internal Thermal Protection
  • Compact 7-lead TO-220 Package
  • Low Cost-Per-Watt
  • Wide Supply Range 9V - 40V
Key Specifications
  • Output Power at 10% THD+N with 1kHz into 4? VCC = 24V 11 W (typ)
  • Output Power at 10% THD+N with 1kHz into 8? VCC = 24V 7 W (typ)
  • Closed Loop Gain 34 dB?(typ)
  • PO at 10% THD+N @ 1 kHz into 4? Single-Ended DDPAK Package VCC = 12V 2.5 W (typ)
  • PO at 10% THD+N @ 1kHz into 8? Bridged DDPAK Package VCC = 12V 5 W (typ)
All trademarks are the property of their respective owners.
The LM4752 is a stereo audio amplifier capable of delivering 11W per channel of continuous average output power to a 4? load, or 7W per channel into 8? using a single 24V supply at 10% THD+N.
The LM4752 is specifically designed for single supply operation and a low external component count. The gain and bias resistors are integrated on chip, resulting in a 11W stereo amplifier in a compact 7 pin TO-220 package. High output power levels at both 20V and 24V supplies and low external component count offer high value for compact stereo and TV applications. A simple mute function can be implemented with the addition of a few external components.
