公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
725mW 单声道、模拟输入 AB 类音频放大器
Audio input type Analog Input
Architecture Class-AB
Speaker channels (Max) Mono
Power stage supply (Max) (V) 5.5
Power stage supply (Min) (V) 2.7
Load (Min) (ohms) 4
Output power (W) 0.85
THD + N @ 1 kHz (%) 0.7
Iq (Typ) (mA) 3.6
Control interface Hardware
Closed/open loop Open
Analog supply (Min) (V) 2.7
Analog supply (Max) (V) 5.5
PSRR (dB) 50
Operating temperature range (C) -40 to 85
  • VSSOP, SOIC, PDIP, and WSON Packaging
  • No Output Coupling Capacitors, Bootstrap Capacitors, or Snubber Circuits are Necessary
  • Thermal Shutdown Protection Circuitry
  • Unity-Gain Stable
  • External Gain Configuration Capability
Key Specifications
  • PO at 1% THD+N with VDD = 5V, 1kHz
    • LM4864LD, 4? load 625 mW (typ)
    • LM4864LD, 8? load 725 mW (typ)
    • LM4864M & LM4864N, 8? load 675 mW (typ)
    • LM4864MM, 8? load 300 mW (typ)
    • LM4864, 16? load 550 mW (typ)
    • Shutdown current 0.7 μA (typ)
All trademarks are the property of their respective owners. Boomer is a trademark of Texas Instruments.
The LM4864 is a bridged audio power amplifier capable of delivering 725mW of continuous average power into an 8Ω load with 1% THD+N from a 5V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power from a low supply voltage while requiring a minimal amount of external components. Since the LM4864 does not require output coupling capacitors, bootstrap capacitors or snubber networks, it is optimally suited for low-power portable applications.
The LM4864 features an externally controlled, low power consumption shutdown mode, and thermal shutdown protection.
The closed loop response of the unity-gain stable LM4864 can be configured by external gain-setting resistors. The device is available in multiple package types to suit various applications.
