公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
6W 立体声、9.5V 至 18V 电源、模拟输入 AB 类音频放大器
Audio input type Analog Input
Architecture Class-AB
Speaker channels (Max) Stereo
Power stage supply (Max) (V) 18
Power stage supply (Min) (V) 9.5
Load (Min) (ohms) 4
Output power (W) 6
SNR (dB) 84
THD + N @ 1 kHz (%) 0.1
Iq (Typ) (mA) 0.007
Control interface Hardware
Analog supply (Min) (V) 9.5
Analog supply (Max) (V) 18
PSRR (dB) 65
Operating temperature range (C) -40 to 85
  • TDA1517P Compatible
  • High Power Outputs (6 W/Channel)
  • Surface Mount Availability 20-Pin Thermal SOIC PowerPAD?
  • Thermal Protection
  • Fixed Gain: 20 dB
  • Mute and Standby Operation
  • Supply Range: 9.5 V - 18 V
PowerPAD is a trademark of Texas Instruments
The TPA1517 is a stereo audio power amplifier that contains two identical amplifiers capable of delivering 6 W per channel of continuous average power into a 4- load at 10% THD+N or 5 W per channel at 1% THD+N. The gain of each channel is fixed at 20 dB. The amplifier features a mute/standby function for power-sensitive applications. The amplifier is available in the PowerPAD? 20-pin surface-mount thermally-enhanced package (DWP) that reduces board space and facilitates automated assembly while maintaining exceptional thermal characteristics. It is also available in the 20-pin thermally enhanced DIP package (NE).
