公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
具有静音功能和待机模式的 Overture 音频功率放大器串联双路 20 瓦音频功率放大器
Speaker channels (Max) Stereo
Power stage supply (Max) (V) 64
Power stage supply (Min) (V) 20
Load (Min) (ohms) 4
Output power (W) 20
THD + N @ 1 kHz (%) 0.08
Iq (Typ) (mA) 25
Control interface Hardware
Closed/open loop Open
Analog supply (Min) (V) 20
Analog supply (Max) (V) 64
PSRR (dB) 115
Operating temperature range (C) -20 to 85
  • SPiKe Protection
  • Minimal Amount of External Components Necessary
  • Quiet Fade-In/Out Mute Mode
  • Standby-Mode
  • Isolated 15-Lead TO-220 Package (PFM)
  • Non-Isolated 15-lead TO-220 Package
  • Wide Supply Range 20V - 64V
Key Specifications
  • THD+N at 1kHz at 2 x 15W continuous averageoutput power into 4Ω or 8Ω: 0.1% (max)
  • THD+N at 1kHz at continuous average output power of 2 x 20W into 8Ω: 0.009% (typ)
  • Standby current: 4.2mA (typ)
All trademarks are the property of their respective owners.
The LM1876 is a stereo audio amplifier capable of delivering typically 20W per channel of continuous average output power into a 4Ω or 8Ω load with less than 0.1% THD+N.
Each amplifier has an independent smooth transition fade-in/out mute and a power conserving standby mode which can be controlled by external logic.
The performance of the LM1876, utilizing its Self Peak Instantaneous Temperature (°Ke) (SPiKe) protection circuitry, places it in a class above discrete and hybrid amplifiers by providing an inherently, dynamically protected Safe Operating Area (SOA). SPiKe protection means that these parts are safeguarded at the output against overvoltage, undervoltage, overloads, including thermal runaway and instantaneous temperature peaks.
