公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
具有静音功能的 μPot 2 通道 78dB 音频衰减器
Number of channels (#) 2
Power supply (V) 4.5 to 15
Gain & attenuation (dB) 0dB to -78dB with 0.5dB steps
THD + N @ 1 kHz (%) 0.0008
Interchannel crosstalk @ 1 kHz (dBFS) -110
Dynamic range (dB) 115
Operating temperature range (C) 0 to 70
Rating Catalog
  • 3-Wire Serial Interface
  • Daisy-Chain Capability
  • 104dB Mute Attenuation
  • Pop and Click Free Attenuation Changes
Key Specifications
  • Total Harmonic Distortion +
    Noise: 0.003 % (max)
  • Frequency response: 100 kHz (?3dB) (min)
  • Attenuation range (excluding
    mute): 78 dB (typ)
  • Differential attenuation: ±0.25 dB (max)
  • Signal-to-noise ratio
    (ref. 4 Vrms): 110 dB (min)
  • Channel separation: 100 dB (min)
All trademarks are the property of their respective owners.
The LM1972 is a digitally controlled 2-channel 78dB audio attenuator fabricated on a CMOS process. Each channel has attenuation steps of 0.5dB from 0dB–47.5dB, 1.0dB steps from 48dB–78dB, with a mute function attenuating 104dB. Its logarithmic attenuation curve can be customized through software to fit the desired application.
The performance of a μPot is demonstrated through its excellent Signal-to-Noise Ratio, extremely low (THD+N), and high channel separation. Each μPot contains a mute function that disconnects the input signal from the output, providing a minimum attenuation of 96dB. Transitions between any attenuation settings are pop free.
The LM1972's 3-wire serial digital interface is TTL and CMOS compatible; receiving data that selects a channel and the desired attenuation level. The Data-Out pin of the LM1972 allows multiple μPots to be daisy-chained together, reducing the number of enable and data lines to be routed for a given application.
