公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
Dual, 30-V, 3-MHz, low noise (8-nV/√Hz) operational amplifier
Number of channels (#) 2
Total supply voltage (Min) (+5V=5, +/-5V=10) 10
Total supply voltage (Max) (+5V=5, +/-5V=10) 30
GBW (Typ) (MHz) 3
Slew rate (Typ) (V/us) 1.7
Rail-to-rail No
Vos (offset voltage @ 25 C) (Max) (mV) 6
Iq per channel (Typ) (mA) 1.25
Vn at 1 kHz (Typ) (nV/rtHz) 8
Features Standard Amps
THD + N @ 1 kHz (Typ) (%) 0.0005
Rating Catalog
Operating temperature range (C) -40 to 85, 0 to 70
Output current (Typ) (mA) 10
Architecture Bipolar
CMRR (Typ) (dB) 90
Input bias current (Max) (pA) 500000
  • Continuous Short-Circuit Protection
  • Wide Common-Mode and Differential Voltage Ranges
  • No Frequency Compensation Required
  • Low Power Consumption
  • No Latch-Up
  • Unity-Gain Bandwidth: 3 MHz Typ
  • Gain and Phase Match Between Amplifiers
  • Low Noise: 8 nV/√Hz Typ at 1 kHz
  • APPLICATIONS
    • DVD Recorders and Players
    • Pro Audio Mixers
All other trademarks are the property of their respective owners
The RC4558 device is a dual general-purpose operational amplifier, with each half electrically similar to the μA741, except that offset null capability is not provided.
The high common-mode input voltage range and the absence of latch-up make this amplifier ideal for voltage-follower applications. The device is short-circuit protected, and the internal frequency compensation ensures stability without external components.
