公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
4 通道、25MHz、低噪声音频运算放大器
Number of channels (#) 4
Total supply voltage (Min) (+5V=5, +/-5V=10) 10
Total supply voltage (Max) (+5V=5, +/-5V=10) 36
GBW (Typ) (MHz) 10
Slew rate (Typ) (V/us) 10
Rail-to-rail No
Vos (offset voltage @ 25 C) (Max) (mV) 5
Iq per channel (Typ) (mA) 2.5
Vn at 1 kHz (Typ) (nV/rtHz) 4.5
Features Standard Amps
THD + N @ 1 kHz (Typ) (%) 0.0015
Rating Catalog
Operating temperature range (C) -40 to 85
Output current (Typ) (mA) 40
Architecture Bipolar
CMRR (Typ) (dB) 100
Input bias current (Max) (pA) 1000000
  • High Slew Rate 10 V/μs (typ); 8 V/μs (min)
  • Wide Gain Bandwidth Product 25 MHz (typ); 15 MHz (min)
  • Power Bandwidth 200 kHz (typ)
  • High Output Current ±40 mA
  • Excellent Output Drive Performance >600Ω
  • Low Input Noise Voltage 4.5 nV/√Hz
  • Low Total Harmonic Distortion 0.0015%
  • Low Offset Voltage 0.3 mV
All trademarks are the property of their respective owners.
The LM837 is a quad operational amplifier designed for low noise, high speed and wide bandwidth performance. It has a new type of output stage which can drive a 600Ω load, making it ideal for almost all digital audio, graphic equalizer, preamplifiers, and professional audio applications. Its high performance characteristics also make it suitable for instrumentation applications where low noise is the key consideration.
The LM837 is internally compensated for unity gain operation. It is pin compatible with most other standard quad op amps and can therefore be used to upgrade existing systems with little or no change.
