公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
5W 单声道、12V 至 26V 电源电压、模拟输入 AB 类音频放大器
Audio input type Analog Input
Architecture Class-AB
Speaker channels (Max) Mono
Power stage supply (Max) (V) 26
Power stage supply (Min) (V) 12
Load (Min) (ohms) 4
Output power (W) 5
THD + N @ 1 kHz (%) 0.25
Iq (Typ) (mA) 8.5
Control interface Hardware
Closed/open loop Open
Analog supply (Min) (V) 12
Analog supply (Max) (V) 26
PSRR (dB) 31
Operating temperature range (C) 0 to 70
  • Wide Supply Voltage Range: 12V to 26V
  • Low Quiescent Power Drain
  • Voltage Gain Fixed at 50
  • High Peak Current Capability: 1.3A
  • Input Referenced to GND
  • High Input Impedance: 150k?
  • Low Distortion: 0.25% (PO=4W, RL=8?)
  • Quiescent Output Voltage is at One Half of the Supply Voltage
  • 14-Pin PDIP Package
All trademarks are the property of their respective owners.
The LM384 is a power audio amplifier for consumer applications. In order to hold system cost to a minimum, gain is internally fixed at 34 dB. A unique input stage allows ground referenced input signals. The output automatically self-centers to one-half the supply voltage.
The output is short-circuit proof with internal thermal limiting. The package outline is standard dual-in-line. A copper lead frame is used with the center three pins on either side comprising a heat sink. This makes the device easy to use in standard p-c layout.
Uses include simple phonograph amplifiers, intercoms, line drivers, teaching machine outputs, alarms, ultrasonic drivers, TV sound systems, AM-FM radio and sound projector systems. See SNAA086 for circuit details.
