Function | Differential |
Additive RMS jitter (Typ) (fs) | 40 |
Output frequency (Max) (MHz) | 650 |
Number of outputs | 10 |
Output supply voltage (V) | 1.8 |
Core supply voltage (V) | 1.8 |
Output skew (ps) | 64 |
Features | I2C interface |
Operating temperature range (C) | -40 to 85 |
Rating | Catalog |
Output type | CML |
Input type | LVDS |
- Single 1.8-V Supply
- High-Performance Clock Distributor with
10 Outputs - Low Input-to-Output Additive Jitter:
as Low as 10fs RMS - Output Group Phase Adjustment
- Low-Voltage Differential Signaling (LVDS)
Input, 100-Ω Differential On-Chip
Termination, up to 650 MHz Frequency - Differential Current Mode Logic (CML)
Outputs, 50-Ω Single-Ended On-Chip
Termination, up to 650 MHz Frequency - Two Groups of Five Outputs Each with
Independent Frequency Division Ratios - Output Frequency Derived with Divide
Ratios of 1, 2, 4, 5, 8, 10, 16, 20,
32, 40, and 80 - Meets ANSI TIA/EIA-644-A-2001 LVDS
Standard Requirements - Power Consumption: 410 mW Typical
- Output Enable Control for Each Output
and Automatic Output Synchronization - SDA/SCL Device Management Interface
- 48-pin VQFN (RGZ) Package
- Industrial Temperature Range:
–40°C to +85°C
The CDCL1810 is a high-performance clock distributor. The programmable dividers, P0 and P1, give a high flexibility to the ratio of the output frequency to the input frequency: FOUT = FIN/P, where: P (P0,P1) = 1, 2, 4, 5, 8, 10, 16, 20, 32, 40, 80.
The CDCL1810 supports one differential LVDS clock input and a total of 10 differential CML outputs. The CML outputs are compatible with LVDS receivers if they are ac-coupled.
With careful observation of the input voltage swing and common-mode voltage limits, the CDCL1810 can support a single-ended clock input as outlined in Pin Configuration and Functions.
All device settings are programmable through the SDA/SCL, serial two-wire interface. The serial interface is 1.8V tolerant only.
The phase of one output group relative to the other can be adjusted through the SDA/SCL interface. For post-divide ratios (P0, P1) that are multiples of 5, the total number of phase adjustment steps (η) equals the divide-ratio divided by 5. For post-divide ratios (P0, P1) that are not multiples of 5, the total number of steps (η) is the same as the post-divide ratio. The phase adjustment step (ΔΦ) in time units is given as: ΔΦ = 1/(n?×?FOUT), where FOUT is the respective output frequency.
The device operates in a 1.8-V supply environment and is characterized for operation from –40°C to +85°C. The CDCL1810 is available in a 48-pin VQFN (RGZ) package.
