公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
具有 8 路输出的 3.3V x4 时钟倍频器
Function Zero-delay
Additive RMS jitter (Typ) (fs) 120
Output frequency (Max) (MHz) 180
Number of outputs 8
Output supply voltage (V) 3.3
Core supply voltage (V) 3.3
Output skew (ps) 150
Features Spread spectrum clocking (SSC)
Operating temperature range (C) -40 to 85
Rating Catalog
Output type LVTTL
Input type LVTTL
  • Phase-Locked Loop-Based Multiplier by Four
  • Input Frequency Range: 2.5 MHz to 45 MHz
  • Output Frequency Range: 10 MHz to 180 MHz
  • LVCMOS/LVTT I/O Compatible
  • Low Jitter (Cycle-Cycle): ±120 ps Over the Range 75 MHz to 180 MHz
  • Distributes One Clock Input to Two Banks of Four Outputs
  • Auto Frequency Detection to Disable Device (Power-Down Mode)
  • Operates From Single 3.3-V Supply
  • Industrial Temperature Range –40°C to 85°C
  • 25- On-Chip Series Damping Resistors
  • No External RC Network Required
  • Spread Spectrum Clock Compatible (SSC)
  • Available in 16-Pin TSSOP Package
The CDCVF25084 is a high-performance, low-skew, low-jitter, phase-lock loop clock multiplier. It uses a PLL to precisely align, in both frequency and phase, the output clocks to the input clock signal including a multiplication factor of four. The CDCVF25084 operates from a nominal supply voltage of 3.3 V. The device also includes integrated series-damping resistors in the output drivers that make it ideal for driving point-to-point loads.
Two banks of four outputs each provide low-skew, low-jitter copies of CLKIN x four. All outputs operate at the same frequency. Output duty cycles are adjusted to 50%, independent of duty cycle at CLKIN. The device automatically goes into power-down mode when no input signal is applied to CLKIN and the outputs go into a low state. Unlike many products containing PLLs, the CDCVF25084 does not require an external RC network. The loop filter for the PLL is included on-chip, minimizing component count, space, and cost.
Because it is based on a PLL circuitry, the CDCVF25084 requires a stabilization time to achieve phase lock of the feedback signal to the reference signal. This stabilization is required following power up and application of a fixed-frequency signal at CLKIN and any following changes to the PLL reference.
The CDCVF25084 is characterized for operation from ?40°C to 85°C.
