公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
1:9 差动 LVPECL 时钟驱动器
Function Differential
Output frequency (Max) (MHz) 650
Number of outputs 9
Output supply voltage (V) 3.3
Core supply voltage (V) 3.3
Output skew (ps) 50
Features 1:9 fanout
Operating temperature range (C) -40 to 85
Rating Catalog
Output type LVPECL
Input type LVPECL
  • Low-Output Skew for Clock-Distribution Applications
  • Differential Low-Voltage Pseudo-ECL (LVPECL) Compatible Inputs and Outputs
  • Distributes Differential Clock Inputs to Nine Differential Clock Outputs
  • Output Reference Voltage (VREF) Allows Distribution From a Single-Ended Clock Input
  • Packaged In a 28-Pin Plastic Chip Carrier
The differential LVPECL clock-driver circuit distributes one pair of differential LVPECL clock inputs (CLKIN, CLKIN)\ to nine pairs of differential clock (Y, Y)\ outputs with minimum skew for clock distribution. It is specifically designed for driving 50- transmission lines.
The VREF output can be strapped to the CLKIN\ input for a single-ended CLKIN input.
The CDCVF111 is characterized for operation from ?40°C to 85°C.
