1 / 1
公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  210粉丝
--- 产品详情 ---
通用和 PCI-X 1:4 LVCMOS 时钟缓冲器
Function Single-ended
Additive RMS jitter (Typ) (fs) 56
Output frequency (Max) (MHz) 200
Number of outputs 4
Output supply voltage (V) 2.5, 3.3
Core supply voltage (V) 2.5, 3.3
Output skew (ps) 150
Features 1:4 fanout
Operating temperature range (C) -40 to 85
Rating Catalog
Output type LVTTL
Input type LVTTL
  • General-Purpose and PCI-X 1:4 Clock Buffer
  • Operating Frequency
    • 0 MHz to 200 MHz General-Purpose
  • Low Output Skew: <100 ps
  • Distributes One Clock Input to One Bank of Four Outputs
  • Output Enable Control that Drives Outputs Low when OE is Low
  • Operates from Single 3.3-V Supply or 2.5-V Supply
  • PCI-X Compliant
  • 8-Pin TSSOP Package
The CDCV304 is a high-performance, low-skew, general-purpose PCI-X compliant clock buffer. It distributes one input clock signal (CLKIN) to the output clocks (1Y[0:3]). It is specifically designed for use with PCI-X applications. The CDCV304 operates at 3.3 V and 2.5 V and is therefore compliant to the 3.3-V PCI-X specifications.
The CDCV304 is characterized for operation from –40°C to 85°C for automotive and industrial applications.
