公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
Direct RAMBus 时钟发生器 - Lite 版
Function Memory interface
Additive RMS jitter (Typ) (fs) 300
Output frequency (Max) (MHz) 400
Number of outputs 2
Output supply voltage (V) 3.3, 1.8
Core supply voltage (V) 3.3, 1.8
Output skew (ps) 0
Features Rambus XDR
Operating temperature range (C) -40 to 85
Rating Catalog
Output type LVCMOS
Input type CMOS
  • 400-MHz Differential Clock Source for Direct Rambus Memory Systems for an 800-MHz Data Transfer Rate
  • Operates From Two (3.3-V and 1.80-V) Power Supplies With 180 mW (Typ) at 400 MHz Total
  • Packaged in a Thin Shrink Small-Outline Package (PW)
  • External Crystal Required for Input
Direct Rambus and Rambus are trademarks of Rambus Inc.
The Direct Rambus clock generator - lite (DRCG-Lite) is an independent crystal clock generator. It performs clock multiplication using PLL, sourced by an internal crystal oscillator. It provides one differential, high-speed Rambus channel compatible output pair. Also, one single-ended output is available to deliver 1/2 of the crystal frequency. The Rambus channel operates at up to 400 MHz with an option to select 300 MHz as well. The desired crystal is a 18.75-MHz crystal in a series resonance fundamental application.
The CDCR61A is characterized for operation over free-air temperatures of 0°C to 85°C.
