公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
3.3V 6 位反相器/时钟驱动器
Function Single-ended
Output frequency (Max) (MHz) 40
Number of outputs 6
Output supply voltage (V) 3.3
Core supply voltage (V) 3.3
Output skew (ps) 700
Operating temperature range (C) 25 to 70
Rating Catalog
Output type CMOS
Input type CMOS
  • Replaces 74AC11203
  • Low-Skew Propagation Delay Specifications for Clock Driver Applications
  • Operates at 3.3-V VCC
  • Flow-Through Architecture Optimizes PCB Layout
  • Center-Pin VCC and GND Pin Configurations Minimize High-Speed Switching Noise
  • EPICTM (Enhanced-Performance Implanted CMOS) 1-m Process
  • 500-mA Typical Latch-Up Immunity at 125°C
  • Packaged in Plastic Small-Outline Package
    EPIC is a trademark of Texas Instruments Incorporated.
The CDC203 contains six independent inverters. The device performs the Boolean function Y = A\. It is designed specifically for applications requiring low skew between switching outputs.
The CDC203 is characterized for operation from 25°C to 70°C.
