公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
5V 6 位反相器/时钟驱动器
Function Single-ended
Output frequency (Max) (MHz) 80
Number of outputs 6
Output supply voltage (V) 5
Core supply voltage (V) 5
Output skew (ps) 1000
Operating temperature range (C) 25 to 70
Rating Catalog
Output type CMOS
Input type CMOS
  • CDC204 Replaces 74AC11204
  • Low-Skew Propagation Delay Specifications for Clock-Driver Applications
  • CMOS-Compatible Inputs and Outputs
  • Flow-Through Architecture Optimizes
    PCB Layout
  • Center-Pin VCC and GND Pin Configurations Minimize High-Speed Switching Noise
  • EPICTM (Enhanced-Performance Implanted CMOS) 1-um Process
  • 500-mA Typical Latch-Up Immunity at 125°C
  • Package Options Include Plastic Small-Outline Package (DW))
    EPIC is a trademark of Texas Instruments Incorporated.
The CDC204 contains six independent inverters. The device performs the Boolean function Y = A\. It is designed specifically for applications requiring low skew between switching outputs.
The CDC204 is characterized for operation from TA = 25°C to 70°C.
