1 / 2
公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  212粉丝
--- 产品详情 ---
5V 双路 1:4 时钟驱动器
Function Single-ended
Output frequency (Max) (MHz) 60
Number of outputs 8
Output supply voltage (V) 5
Core supply voltage (V) 5
Output skew (ps) 1000
Features Dual 1:4 fanout
Operating temperature range (C) -40 to 85
Rating Catalog
Output type CMOS
Input type TTL
  • Low-Skew Propagation Delay Specifications for Clock-Driver Applications
  • TTL-Compatible Inputs and CMOS-Compatible Outputs
  • Flow-Through Architecture Optimizes
    PCB Layout
  • Center-Pin VCC and GND Pin Configurations Minimize High-Speed Switching Noise
  • EPICTM (Enhanced-Performance Implanted CMOS) 1-um Process
  • 500-mA Typical Latch-Up Immunity at 125°C
  • Package Options Include Plastic Small-Outline (DW)
EPIC is a trademark of Texas Instruments Incorporated.
The CDC208 contains dual clock-driver circuits that fanout one input signal to four outputs with minimum skew for clock distribution (see Figure 2). The device also offers two output-enable (OE1\ and OE2\) inputs for each circuit that can force the outputs to be disabled to a high-impedance state or to a high- or low-logic level independent of the signal on the respective A input.
Skew parameters are specified for a reduced temperature and voltage range common to many applications.
The CDC208 is characterized for operation from -40°C to 85°C.
