公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有可选择极性的 1 至 6 CMOS 时钟驱动器
Function Single-ended
Output frequency (Max) (MHz) 80
Number of outputs 6
Output supply voltage (V) 5
Core supply voltage (V) 5
Features Pin control
Operating temperature range (C) -40 to 85
Rating Catalog
Output type CMOS
Input type TTL
  • Low Output Skew for Clock-Distribution and Clock-Generation Applications
  • TTL-Compatible Inputs and CMOS-Compatible Outputs
  • Distributes One Clock Input to Six Clock Outputs
  • Polarity Control Selects True or Complementary Outputs
  • Distributed VCC and GND Pins Reduce Switching Noise
  • High-Drive Outputs (-32-mA IOH,
    32-mA IOL)
  • State-of-the-Art EPIC-II BTM BiCMOS Design Significantly Reduces Power Dissipation
  • Package Options Include Plastic Small-Outline (D)
    EPIC-IIB is a trademark of Texas Instruments Incorporated.
The CDC329A contains a clock-driver circuit that distributes one input signal to six outputs with minimum skew for clock distribution. Through the use of the polarity-control inputs (T\/C), various combinations of true and complementary outputs can be obtained.
The CDC329A is characterized for operation from -40°C to 85°C.
