公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
RTC IC W NVSRAM 控制器、看门狗计时器、加电复位、中断与低电池电量警告
Iq (Typ) (uA) 0.5
Features External SRAM control, Integrated CPU supervisor, Parallel bus interface, 16 RTC bytes
Rating Catalog
Operating temperature range (C) 0 to 70
Supply voltage (Max) (V) 5.5
Supply voltage (Min) (V) 4.5
  • Real-Time Clock counts seconds through years in BCD format
  • On-chip battery-backup switchover circuit with nonvolatile control for external SRAM
  • Less than 500nA of clock operation current in backup mode
  • Microprocessor reset valid to VCC =VSS
  • Independent watchdog timer with a programmable time-out period
  • Power-fail interrupt warning
  • Programmable clock alarm interrupt active in battery-backup mode
  • Programmable periodic interrupt
  • Battery-low warning
The bq4845 Real-Time Clock is a low-power microprocessor peripheral that integrates a time-of-day clock, a 100-year calendar, and a CPU supervisor in a 28-pin SOIC or DIP. The bq4845 is ideal for fax machines, copiers, industrial control systems, point-of-sale terminals, data loggers, and computers.
The bq4845 provides direct connections for a 32.768KHz quartz crystal and a 3V backup battery. Through the use of the conditional chip enable output (CE\OUT) and battery voltage output (VOUT) pins, the bq4845 can write-protect and make nonvolatile external SRAMs. The backup cell powers the real-time clock and maintains SRAM information in the absence of system voltage.
The bq4845 contains a temperature-compensated reference and comparator circuit that monitors the status of its voltage supply. When the bq4845 detects an out-of-tolerance condition, it generates an interrupt warning and subsequently a microprocessor reset. The reset stays active for 200ms after VCC rises within tolerance, to allow for power supply and processor stabilization.
The bq4845 also has a built-in watchdog timer to monitor processor operation. If the microprocessor does not toggle the watchdog input (WDI) within the programmed time-out period, the bq4845 asserts WDO\ and RST\. WDI unconnected disables the watchdog timer.
The bq4845 can generate other interrupts based on a clock alarm condition or a periodic setting. The alarm interrupt can be set to occur from once per second to once per month. The alarm can be made active in the battery-backup mode to serve as a system wake-up call. For interrupts at a rate beyond once per second, the periodic interrupt can be programmed with periods of 30.5us to 500ms.
