Sample rate (Max) (MSPS) | 1600, 3200 |
Resolution (Bits) | 12 |
Number of input channels | 2, 1 |
Interface type | Parallel LVDS |
Analog input BW (MHz) | 2400 |
Features | Ultra High Speed |
Rating | Space |
Input range (Vp-p) | 0.8 |
Power consumption (Typ) (mW) | 3880 |
Architecture | Folding Interpolating |
SNR (dB) | 58.2 |
ENOB (Bits) | 9.3 |
SFDR (dB) | 67.3 |
Operating temperature range (C) | -55 to 125, 25 to 25 |
Input buffer | Yes |
- Total Ionizing Dose (TID) to 300 krad(Si)
- Single Event Latch-up (SEL) > 120 MeV-cm2/mg
- Wide Temperature Range –55°C to +125°C
- Low Power Consumption
- R/W SPI for Extended Control Mode or Simple Pin Control Mode
- Interleaved Timing Automatic with Manual Skew Adjust
- Auto-Sync Function for Multi-Chip Systems
- Time Stamp Feature to Capture External Trigger
- Test Patterns at Output for System Debug
- 1:1 Non-Demuxed or 1:2 or 1:4 Parallel Demuxed LVDS Outputs
- Single 1.9V Power Supply
- 376 CPGA Hermetic Package
The ADC12D1600QML is a low power, high performance CMOS analog-to-digital converter that digitizes signals at a 12-bit resolution at sampling rates up to 3.2 GSPS in an interleaved mode. It can also be used as a dual channel ADC for sampling rates up to 1.6 GSPS. For sampling rates below 800 MHz, there is a Low Sampling Power Saving Mode (LSPSM) that reduces power consumption to less than 1.4 W per channel (typical). The ADC can support conversion rates as low as 200 MSPS.
The ADC1600QML provides a flexible parallel LVDS interface which has multiple SPI programmable options to facilitate board design and ASIC/FPGA data capture. The LVDS outputs are compatible with IEEE 1596.3-1996 and support programmable common mode voltage. The output of each channel is configurable in either 1:1 non-demuxed or 1:2 demuxed modes. If used as a single channel ADC, there is an option for 1:4 demuxing of the output. The product comes in a hermetic 376 CPGA package for harsh environments.
