公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
QMLV、50krad、陶瓷、12 位、单通道、1GSPS ADC
Sample rate (Max) (MSPS) 1000
Resolution (Bits) 12
Number of input channels 1
Interface type Parallel LVDS
Analog input BW (MHz) 2150
Features Ultra High Speed
Rating Space
Input range (Vp-p) 2
Power consumption (Typ) (mW) 2200
Architecture Pipeline
SNR (dB) 58.5
ENOB (Bits) 9.55
SFDR (dB) 77.9
Operating temperature range (C) -55 to 125, 25 to 25
Input buffer Yes
  • 1-GSPS sample rate
  • 12-Bit resolution
  • 2.1 GHz input bandwidth
  • SFDR = 65 dBc at 1.2 GHz
  • SNR = 57 dBFS at 1.2 GHZ
  • 7 Clock cycle latency
  • Interleave friendly: internal adjustments for gain, phase and offset
  • 1.5 - 2 VPP Differential input voltage, programmable
  • LVDS-compatible outputs, 1 or 2 bus options
  • Total power dissipation: 2.2 W
  • On-chip analog buffer
  • 100-pin ceramic nonconductive tie-bar package
  • Military temperature range
    (–55°C to 125°C Tcase)
  • Processed per internal QML class V assembly/test flow
  • QML class V qualified, SMD 5962-09240
The ADS5400 is a 12-bit, 1-GSPS analog-to-digital converter (ADC) that operates from both a 5-V supply and 3.3-V supply, while providing LVDS-compatible digital outputs. The analog input buffer isolates the internal switching of the track and hold from disturbing the signal source. The simple 3-stage pipeline provides extremely low latency for time critical applications. Designed for the conversion of signals up to 2 GHz of input frequency at 1 GSPS, the ADS5400 has outstanding low noise performance and spurious-free dynamic range over a large input frequency range.
The ADS5400 is available in a 100-Pin Ceramic Nonconductive Tie-Bar Package. The combination of the ceramic package and moderate power consumption of the ADS5400 allows for operation without an external heatsink. The ADS5400 is built on Texas Instrument?s complementary bipolar process (BiCom3) and is specified over the full military temperature range (–55°C to 125°C Tcase).
