Sample rate (Max) (MSPS) | 250 |
Resolution (Bits) | 14 |
Number of input channels | 1 |
Interface type | DDR LVDS, Parallel CMOS |
Analog input BW (MHz) | 800 |
Features | High Performance |
Rating | Catalog |
Input range (Vp-p) | 1.5 |
Power consumption (Typ) (mW) | 350 |
Architecture | Pipeline |
SNR (dB) | 69.7 |
ENOB (Bits) | 11.2 |
SFDR (dB) | 89 |
Operating temperature range (C) | -40 to 85 |
Input buffer | Yes |
- ADS41B49: 14-Bit, 250 MSPS
ADS41B29: 12-Bit, 250 MSPS - Integrated High-Impedance
Analog Input Buffer:- Input Capacitance: 2 pF
- 200-MHz Input Resistance: 3 kΩ
- Maximum Sample Rate: 250 MSPS
- Ultralow Power:
- 1.8-V Analog Power: 180 mW
- 3.3-V Buffer Power: 96 mW
- I/O Power: 135 mW (DDR LVDS)
- High Dynamic Performance:
- SNR: 69 dBFS at 170 MHz
- SFDR: 82.5 dBc at 170 MHz
- Output Interface:
- Double Data Rate (DDR) LVDS with Programmable Swing and Strength:
- Standard Swing: 350 mV
- Low Swing: 200 mV
- Default Strength: 100-Ω Termination
- 2x Strength: 50-Ω Termination
- 1.8-V Parallel CMOS Interface Also Supported
- Programmable Gain for SNR, SFDR Trade-Off
- DC Offset Correction
- Supports Low Input Clock Amplitude
- Package: VQFN-48 (7 mm × 7 mm)
The ADS41Bx9 are members of the ultralow-power ADS4xxx analog-to-digital converter (ADC) family, featuring integrated analog input buffers. These devices use innovative design techniques to achieve high dynamic performance, and consume extremely low power. The analog input pins have buffers, with benefits of constant performance and input impedance across a wide frequency range. The devices are well-suited for multi-carrier, wide bandwidth communications applications such as PA linearization.
The ADS41Bx9 have features such as digital gain and offset correction. The gain option can be used to improve SFDR performance at lower full-scale input ranges, especially at high input frequencies. The integrated dc offset correction loop can be used to estimate and cancel the ADC offset. At lower sampling rates, the ADC automatically operates at scaled-down power with no loss in performance.
The devices support both double data rate (DDR) low-voltage differential signaling (LVDS) and parallel CMOS digital output interfaces. The low data rate of the DDR LVDS interface (maximum 500 MBPS) makes using low-cost field-programmable gate array (FPGA)-based receivers possible. The devices have a low-swing LVDS mode that can be used to further reduce the power consumption. The strength of the LVDS output buffers can also be increased to support 50-Ω differential termination.
The devices are available in a compact VQFN-48 package and are specified over the industrial temperature range (–40°C to +85°C).
