Resolution (Bits) | 18 |
Number of input channels | 1 |
Sample rate (Max) (kSPS) | 0.08 |
Interface type | SPI |
Architecture | Delta-Sigma |
Input type | Differential, Single-Ended |
Rating | Catalog |
Reference mode | Ext |
Input range (Max) (V) | 0.041 |
Input range (Min) (V) | 0 |
Features | 50/60 Hz Rejection, Oscillator, PGA |
Operating temperature range (C) | -40 to 85 |
Power consumption (Typ) (mW) | 2.9 |
Analog voltage AVDD (Min) (V) | 2.7 |
Analog voltage AVDD (Max) (V) | 5.3 |
Digital supply (Min) (V) | 2.7 |
Digital supply (Max) (V) | 5.3 |
- 18-Bit Noise-Free Resolution
- Complete Front-End for Bridge Sensor
- Onboard Gain of 64
- Onboard Oscillator
- Selectable 10SPS or 80SPS Data Rates
- Simultaneous 50Hz and 60Hz Rejection at 10SPS
- External Voltage Reference up to 5V for Ratiometric Measurements
- Simple, Pin-Driven Control
- Two-Wire Serial Digital Interface
- Tiny TSSOP-16 Package
- Supply Range: 2.7V to 5.3V
- APPLICATIONS
- Weigh Scales
- Strain Gauges
All trademarks are the property of their respective owners.
The ADS1130 is a precision, 18-bit analog-to-digital converter (ADC). With an onboard low-noise gain amplifier, onboard oscillator, and precision 18-bit delta-sigma ADC, the ADS1130 provides a complete front-end solution for bridge sensor applications including weigh scales and strain gauges.
The low-noise amplifier has a gain of 64, supporting a full-scale differential input of ±39mV. The delta-sigma ADC has 18-bit effective resolution and is comprised of a third-order modulator and fourth-order digital filter. Two data rates are supported: 10SPS (with both 50Hz and 60Hz rejection) and 80SPS. The ADS1130 can be put into a low-power standby mode or shut off completely in power-down mode.
All of the features of the ADS1130 are controlled by dedicated pins; there are no digital registers to program. Data are output over an easily-isolated serial interface that connects directly to the MSP430 and other microcontrollers.
The ADS1130 is available in a TSSOP-16 package and is specified for operation from -40°C to +85°C.
