公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
汽车类 12 位 4 通道串行输出采样模数转换器 (ADC)
Resolution (Bits) 12
Number of input channels 4
Sample rate (Max) (kSPS) 200
Interface type SPI
Architecture SAR
Input type Single-Ended
Multi-channel configuration Multiplexed
Rating Automotive
Reference mode Ext
Input range (Max) (V) 5.25
Input range (Min) (V) 0
Operating temperature range (C) -40 to 125
Power consumption (Typ) (mW) 0.84
Analog voltage AVDD (Min) (V) 2.7
SNR (dB) 73
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 1
Digital supply (Min) (V) 2.7
Digital supply (Max) (V) 5.25
  • Qualified for Automotive Applications
  • Single Supply: 2.7 V To 5 V
  • Four-Channel Single-Ended Or Two-Channel Differential Input
  • Up To 200-kHz Conversion Rate
  • ±2 LSB Max INL and DNL
  • No Missing Codes
  • 71-dB Typ SINAD
  • Serial Interface
  • Alternate Source For MAX1247
The ADS7841 is a 4-channel 12-bit sampling analog-to-digital converter (ADC) with a synchronous serial interface. The resolution is programmable to either 8 bits or 12 bits. Typical power dissipation is 2 mW at a 200-kHz throughput rate and a 5-V supply. The reference voltage (VREF) can be varied between 100 mV and VCC, providing a corresponding input voltage range of 0 V to VREF. The device includes a shutdown mode that reduces power dissipation to under 15 μW. The ADS7841 is specified down to 2.7-V operation.
Low power, high speed, and on-board multiplexer make the ADS7841 ideal for battery-operated systems. The serial interface also provides low-cost isolation for remote data acquisition. The ADS7841 is available in a SSOP-16 package.
