公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有内部基准和串行接口的 12 位 40kSPS 低功耗采样 ADC
Resolution (Bits) 12
Number of input channels 1
Sample rate (Max) (kSPS) 40
Interface type SPI
Architecture SAR
Input type Single-Ended
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 10
Input range (Min) (V) -10
Features Oscillator
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 155
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 74
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 0.5
Digital supply (Min) (V) 4.75
Digital supply (Max) (V) 5.25
  • 40-kHz Minimum Sampling Rate
  • Very Low Power: 25 mW
  • ±3.33-V, ±5-V, ±10-V, 4-V, and 10-V Input Ranges
  • 73.9-dB SINAD with 10-kHz Input
  • ±0.5 LSB Max INL
  • ±0.5 LSB Max DNL, 12-Bit NMC
  • ±5-mV BPZ, ±2 ppm/°C BPZ Drift
  • 72-dB Min SINAD, 80-dB Min SFDR
  • Uses Internal or External 2.5-V Reference
  • No External Calibration Resistors Required
  • Single 5-V Analog Supply:
    • 32.5-mW Max Power Dissipation
    • 50-μW Max Power-Down Mode
  • SPI-Compatible Serial Port up to 20MHz, with Master/Slave Feature
  • Global CONV and 3-Stated Bus for Multi-Chip Simultaneous S/H Operation
  • Pin-Compatible with ADS7812 and 16-Bit ADS7813/8513
  • SO-16 Package
  • APPLICATIONS
    • Industrial Process Control
    • Test Equipment
    • Robotics
    • DSP Servo Control
    • Medical Instrumentation
    • Portable Data Acquisition Systems
The ADS8512 is a complete low-power, single 5-V supply, 12-bit sampling analog-to-digital(A/D) converter. It contains a complete 12-bit capacitor-based, successive approximation register (SAR) A/D converter with sample-and-hold (S/H), clock, reference, and serial data interface. The converter can be configured for a variety of input ranges including ±10 V, ±5 V, 0 V to 10 V, and 0.5 V to 4.5 V. A high-impedance, 0.3-V to 2.8-V input is also available with input impedance greater than 10 MΩ. For most input ranges, the input voltage can swing to 25 V or -25 V without damage to the converter.
An SPI-compatible serial interface allows data to be synchronized to an internal or external clock. The ADS8512 is specified at 40-kHz sampling rate over the -40°C to +85°C industrial temperature range.
