公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
双通道、11 位、105MSPS 模数转换器 (ADC)
Sample rate (Max) (MSPS) 105
Resolution (Bits) 11
Number of input channels 2
Interface type Serial LVDS
Analog input BW (MHz) 1000
Features Low Power
Rating Catalog
Input range (Vp-p) 2
Power consumption (Typ) (mW) 1000
Architecture Pipeline
SNR (dB) 67
ENOB (Bits) 10.9
SFDR (dB) 88
Operating temperature range (C) -40 to 85
Input buffer No
  • Clock Duty Cycle Stabilizer
  • Single +3.0 or +3.3V Supply Operation
  • Serial LVDS Outputs
  • Serial Control Interface
  • Overrange Outputs
  • 60-Pin WQFN Package, (9x9x0.8mm, 0.5mm Pin-Pitch)
Key Specifications
  • Resolution 11 Bits
  • Conversion Rate 105 MSPS
  • SNR (fIN = 240 MHz) 66 dBFS (typ)
  • SFDR (fIN = 240 MHz) 82 dBFS (typ)
  • Full Power Bandwidth 1 GHz (typ)
  • Power Consumption 1 W (typ)
All trademarks are the property of their respective owners.
The ADC11DS105is a high-performance CMOS analog-to-digital converters capable of converting two analog input signals into 11-bit digital words at rates up to 105 Mega Samples Per Second (MSPS). The digital outputs are serialized and provided on differential LVDS signal pairs. These converters use a differential, pipelined architecture with digital error correction and an on-chip sample-and-hold circuit to minimize power consumption and the external component count, while providing excellent dynamic performance. The ADC11DS105 may be operated from a single +3.0 or +3.3V power supply. A power-down feature reduces the power consumption to very low levels while still allowing fast wake-up time to full operation. The differential inputs accept a 2V full scale differential input swing. A stable 1.2V internal voltage reference is provided, or the ADC11DS105 can be operated with an external 1.2V reference. The selectable duty cycle stabilizer maintains performance over a wide range of clock duty cycles. A serial interface allows access to the internal registers for full control of the ADC11DS105's functionality. The ADC11DS105 is available in a 60-lead WQFN package and operates over the industrial temperature range of ?40°C to +85°C.
