公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有串行接口和基准并行的 12 位 40KSPS 模数转换器
Resolution (Bits) 12
Number of input channels 1
Sample rate (Max) (kSPS) 40
Interface type Byte-Wide, Parallel, SPI
Architecture SAR
Input type Single-Ended
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 10
Input range (Min) (V) -10
Features Daisy-Chainable, Oscillator
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 155
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 74
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 0.45
Digital supply (Min) (V) 4.75
Digital supply (Max) (V) 5.25
  • 40-kHz Min Sampling Rate
  • 4-V, 5-V, and ±10-V Input Ranges
  • 73.9-dB SINAD with 10-kHz Input
  • ±0.45 LSB Max INL
  • ±0.45 LSB Max DNL, 12-Bit No Missing Codes
  • ±5-mV BPZ, ±0.5 PPM/°C BPZ Drift
  • SPI Compatible Serial Output With Daisy-Chain (TAG), SPI Master/Slave Feature
  • Single 5-V Analog Supply
  • Pin-Compatible With ADS7806 and 16-Bit ADS7807/8507
  • Uses Internal or External 2.5-V Reference
  • Low Power Dissipation
    • 24 mW Typ, 30 mW Max at 40 KSPS
  • 50-μW Max Power Down Mode
  • 28-Pin SO Package
  • Full Parallel Interface
  • 2’s Comp or BTC Output Code
  • APPLICATIONS
    • Industrial Process Control
    • Test Equipment
    • Medical Equipment
    • Data Acquisition Systems
    • Digital Signal Processing
    • Instrumentation
QSPI, SPI are trademarks of Motorola.
The ADS8506 is a complete low power, single 5-V supply, 12-bit sampling analog-to-digital (A/D) converter. It contains a complete 12-bit capacitor-based, successive approximation register (SAR) A/D converter with sample and hold, clock, reference, and data interface. The converter can be configured for a variety of input ranges including ±10 V, 4 V, and 5 V. For most input ranges, the input voltage can swing to 25 V or ?25 V without damage to the converter.
A SPI compatible serial interface allows data to be synchronized to an internal or external clock. A full parallel interface with BYTE select is also provided to allow the maximum system design flexibility. The ADS8506 is specified at 40 kHz sampling rate over the industrial ?40°C to 85°C temperature range.
