公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
12 位、80MSPS、1.0GHz 输入带宽模数转换器 (ADC)
Sample rate (Max) (MSPS) 80
Resolution (Bits) 12
Number of input channels 1
Interface type Parallel CMOS
Analog input BW (MHz) 1000
Features Low Power
Rating Catalog
Input range (Vp-p) 2
Power consumption (Typ) (mW) 300
Architecture Pipeline
SNR (dB) 71.2
ENOB (Bits) 11.5
SFDR (dB) 90
Operating temperature range (C) -40 to 85
Input buffer No
  • 1 GHz Full Power Bandwidth
  • Internal Reference and Sample-and-Hold Circuit
  • Low Power Consumption
  • Data Ready Output Clock
  • Clock Duty Cycle Stabilizer
  • Single +3.0V Supply Operation
  • Power-Down Mode
  • 32-Pin WQFN Package, (5x5x0.8mm, 0.5mm Pin-Pitch)
Key Specifications
  • Resolution 12 Bits
  • Conversion Rate 80 MSPS
  • SNR (fIN = 170 MHz) 68 dBFS (typ)
  • SFDR (fIN = 170 MHz) 86 dBFS (typ)
  • Full Power Bandwidth 1 GHz (typ)
  • Power Consumption 300 mW (typ)
All trademarks are the property of their respective owners.
The ADC12C080 is a high-performance CMOS analog-to-digital converter capable of converting analog input signals into 12-bit digital words at rates up to 80 Mega Samples Per Second (MSPS). This converter uses a differential, pipelined architecture with digital error correction and an on-chip sample-and-hold circuit to minimize power consumption and the external component count, while providing excellent dynamic performance. A unique sample-and-hold stage yields a full-power bandwidth of 1 GHz. The ADC12C080 may be operated from a single +3.0V power supply and consumes low power. A separate +2.5V supply may be used for the digital output interface which allows lower power operation with reduced noise. A power-down feature reduces the power consumption to very low levels while still allowing fast wake-up time to full operation. The differential inputs accept a 2V full scale differential input swing. A stable 1.2V internal voltage reference is provided, or the ADC12C080 can be operated with an external 1.2V reference. Output data format (offset binary versus 2's complement) and duty cycle stabilizer are pin-selectable. The duty cycle stabilizer maintains performance over a wide range of clock duty cycles.
The ADC12C080 is available in a 32-lead WQFN package and operates over the industrial temperature range of ?40°C to +85°C.
