Resolution (Bits) | 16 |
Number of input channels | 1 |
Sample rate (Max) (kSPS) | 250 |
Interface type | Byte-Wide, Parallel |
Architecture | SAR |
Input type | Single-Ended |
Rating | Catalog |
Reference mode | Ext, Int |
Input range (Max) (V) | 10 |
Input range (Min) (V) | -10 |
Features | Oscillator |
Operating temperature range (C) | -40 to 85 |
Power consumption (Typ) (mW) | 155 |
Analog voltage AVDD (Min) (V) | 4.75 |
SNR (dB) | 92 |
Analog voltage AVDD (Max) (V) | 5.25 |
INL (Max) (+/-LSB) | 2 |
Digital supply (Min) (V) | 1.65 |
Digital supply (Max) (V) | 5.25 |
- Standard ±10-V Input Range
- 90-dB Min SNR with 20-kHz Input
- ±2.0 LSB Max INL
- ±1 LSB Max DNL, 16 Bits, No Missing Code
- 5-V Analog Supply, Flexible I/O Supply Voltage at 1.65 V to 5.25 V
- Pin-Compatible with ADS7805/10 (Low Speed), and 12-Bit ADS7804/8504
- Uses Internal or External Reference
- Full Parallel Data Output
- 100-mW Typ Power Dissipation at 250 kSPS
- 28-Pin SSOP Package
- APPLICATIONS
- Industrial Process Control
- Data Acquisition Systems
- Digital Signal Processing
- Medical Equipment
- Instrumentation
All other trademarks are the property of their respective owners
The ADS8515 is a complete 16-bit sampling analog-to-digital (A/D) converter using state-of-the-art CMOS structures. It contains a complete 16-bit, capacitor-based, SAR A/D converter with sample and hold (S/H), reference, clock, interface for microprocessor use, and 3-state output drivers.
The ADS8515 is specified at a 250-kHz sampling rate over the full temperature range. Precision resistors provide an industry standard ±10-V input range, while the innovative design allows operation from a single +5-V supply, with power dissipation under 100 mW.
The ADS8515 is available in a 28-pin SSOP package and is fully specified for operation over the industrial –40°C to 85°C temperature range.
