Sample rate (Max) (MSPS) | 170 |
Resolution (Bits) | 12 |
Number of input channels | 1 |
Interface type | DDR LVDS, Parallel LVDS |
Analog input BW (MHz) | 1100 |
Features | Low Power |
Rating | Catalog |
Input range (Vp-p) | 2 |
Power consumption (Typ) (mW) | 781 |
Architecture | Pipeline |
SNR (dB) | 67.9 |
ENOB (Bits) | 11 |
SFDR (dB) | 85.8 |
Operating temperature range (C) | -40 to 85 |
Input buffer | No |
- 1.1 GHz Full Power Bandwidth
- Internal Sample-and-Hold Circuit
- Internal Precision 1.0V Reference
- Single-Ended or Differential Clock Modes
- Clock Duty Cycle Stabilizer
- Dual +3.3V and +1.8V Supply Operation
- Power-Down and Sleep Modes
- Offset Binary or 2's Complement Output Data Format
- LVDS Outputs
- Pin-Compatible: ADC14V155
- 48-Pin WQFN Package, (7x7x0.8mm, 0.5mm Pin-Pitch)
Key Specifications
- Resolution: 12 Bits
- Conversion Rate: 170 MSPS
- SNR (fIN = 70 MHz): 67.2 dBFS (Typ)
- SFDR (fIN = 70 MHz): 85.8 dBFS (Typ)
- ENOB (fIN = 70 MHz): 10.9 Bits (Typ)
- Full Power Bandwidth: 1.1 GHZ (Typ)
- Power Consumption: 781 mW (Typ)
All trademarks are the property of their respective owners.
The ADC12V170 is a high-performance CMOS analog-to-digital converter with LVDS outputs. It is capable of converting analog input signals into 12-Bit digital words at rates up to 170 Mega Samples Per Second (MSPS). Data leaves the chip in a DDR (Dual Data Rate) format; this allows both edges of the output clock to be utilized while achieving a smaller package size. This converter uses a differential, pipelined architecture with digital error correction and an on-chip sample-and-hold circuit to minimize power consumption and the external component count, while providing excellent dynamic performance. A unique sample-and-hold stage yields a full-power bandwidth of 1.1 GHz. The ADC12V170 operates from dual +3.3V and +1.8V power supplies and consumes 781 mW of power at 170 MSPS.
The separate +1.8V supply for the digital output interface allows lower power operation with reduced noise. A power-down feature reduces the power consumption to 15 mW while still allowing fast wake-up time to full operation. In addition there is a sleep feature which consumes 50 mW of power and has a faster wake-up time.
The differential inputs provide a full scale differential input swing equal to 2 times the reference voltage. A stable 1.0V internal voltage reference is provided, or the ADC12V170 can be operated with an external reference.
Clock mode (differential versus single-ended) and output data format (offset binary versus 2's complement) are pin-selectable. A duty cycle stabilizer maintains performance over a wide range of input clock duty cycles.
The ADC12V170 is pin-compatible with the ADC14V155. It is available in a 48-lead WQFN package and operates over the industrial temperature range of ?40°C to +85°C.
