公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
11 位、125MSPS 模数转换器 (ADC)
Sample rate (Max) (MSPS) 125
Resolution (Bits) 11
Number of input channels 1
Interface type Parallel CMOS
Analog input BW (MHz) 750
Features Low Power
Rating Catalog
Input range (Vp-p) 2.3
Power consumption (Typ) (mW) 780
Architecture Pipeline
SNR (dB) 66.7
ENOB (Bits) 10.8
SFDR (dB) 84
Operating temperature range (C) -40 to 85
Input buffer No
  • 11-bit Resolution
  • 125-MSPS Sample Rate
  • High SNR: 66.3 dBFS at 100 MHz fIN
  • High SFDR: 81 dBc at 100 MHz fIN
  • 2.3-VPP Differential Input Voltage
  • Internal Voltage Reference
  • 3.3-V Single-Supply Voltage
  • Analog Power Dissipation: 578 mW
  • Serial Programming Interface
  • TQFP-64 PowerPAD Package
  • Pin-Compatible With:
    • ADS5500 (14-Bit, 125 MSPS)
    • ADS5541 (14-Bit, 105 MSPS)
    • ADS5542 (14-Bit, 80 MSPS)
    • ADS5520 (12-Bit, 125 MSPS)
    • ADS5521 (12-Bit, 105 MSPS)
    • ADS5522 (12-Bit, 80 MSPS)
  • Recommended Operational Amplifiers: THS3201, THS3202, THS4503, THS4509, THS9001, OPA695, OPA847
  • APPLICATIONS
    • Wireless Communication
      • Communication Receivers
      • Base Station Infrastructure
    • Test and Measurement Instrumentation
    • Single and Multichannel Digital Receivers
    • Communication Instrumentation
      • Radar
      • Infrared
    • Video and Imaging
    • Medical Equipment
PowerPAD is a trademark of Texas Instruments.
The ADS5510 is a high-performance, 11 bit, 125 MSPS analog-to-digital converter (ADC). To provide a complete converter solution, it includes a high-bandwidth linear sample-and-hold stage (S&H) and internal reference. Designed for applications demanding the highest speed and highest dynamic performance in little space, the ADS5510 has excellent power consumption of 578 mW at 3.3-V single-supply voltage. This allows an even higher system integration density. The provided internal reference simplifies system design requirements. Parallel CMOS-compatible output ensures seamless interfacing with common logic.
The ADS5510 is available in 64-pin TQFP PowerPAD? package over the industrial temperature range.
