Sample rate (Max) (MSPS) | 170 |
Resolution (Bits) | 12 |
Number of input channels | 1 |
Interface type | Parallel CMOS |
Analog input BW (MHz) | 1100 |
Features | Low Power |
Rating | Catalog |
Input range (Vp-p) | 2 |
Power consumption (Typ) (mW) | 715 |
Architecture | Pipeline |
SNR (dB) | 67.5 |
ENOB (Bits) | 10.9 |
SFDR (dB) | 85.4 |
Operating temperature range (C) | -40 to 85 |
Input buffer | No |
- 1.1 GHz Full Power Bandwidth
- Internal Sample-and-Hold Circuit
- Low Power Consumption
- Internal Precision 1.0V Reference
- Single-Ended or Differential Clock Modes
- Clock Duty Cycle Stabilizer
- Dual +3.3V and +1.8V Supply Operation
- Power-Down and Sleep Modes
- Offset Binary or 2's Complement Output Data Format
- Pin-Compatible: ADC14155, ADC11C125, ADC11C170
- 48-Pin WQFN Package, (7x7x0.8mm, 0.5mm Pin-Pitch)
Key Specifications
- Resolution 12 Bits
- Conversion Rate 170 MSPS
- SNR (fIN = 70 MHz) 67.2 dBFS (typ)
- SFDR (fIN = 70 MHz) 85.4 dBFS (typ)
- ENOB (fIN = 70 MHz) 10.8 bits (typ)
- Full Power Bandwidth 1.1 GHz (typ)
- Power Consumption 715 mW (typ)
All trademarks are the property of their respective owners.
The ADC12C170 is a high-performance CMOS analog-to-digital converter capable of converting analog input signals into 12-Bit digital words at rates up to 170 Mega Samples Per Second (MSPS). This converter uses a differential, pipelined architecture with digital error correction and an on-chip sample-and-hold circuit to minimize power consumption and the external component count, while providing excellent dynamic performance. A unique sample-and-hold stage yields a full-power bandwidth of 1.1 GHz. The ADC12C170 operates from dual +3.3V and +1.8V power supplies and consumes 715 mW of power at 170 MSPS.
The separate +1.8V supply for the digital output interface allows lower power operation with reduced noise. A power-down feature reduces the power consumption to 5 mW while still allowing fast wake-up time to full operation. In addition there is a sleep feature which consumes 50 mW of power and has a faster wake-up time.
The differential inputs provide a full scale differential input swing equal to 2 times the reference voltage. A stable 1.0V internal voltage reference is provided, or the ADC12C170 can be operated with an external reference.
Clock mode (differential versus single-ended) and output data format (offset binary versus 2's complement) are pin-selectable. A duty cycle stabilizer maintains performance over a wide range of input clock duty cycles.
The ADC12C170 is pin compatible with the ADC14155, ADC11C125 and ADC11C170.
It is available in a 48-lead WQFN package and operates over the industrial temperature range of ?40°C to +85°C.
