Resolution (Bits) | 20 |
Number of input channels | 1 |
Sample rate (Max) (kSPS) | 0.08 |
Interface type | SPI |
Architecture | Delta-Sigma |
Input type | Differential, Single-Ended |
Rating | Catalog |
Reference mode | Ext |
Input range (Max) (V) | 0.039 |
Input range (Min) (V) | 0 |
Features | 50/60 Hz Rejection, Oscillator, PGA |
Operating temperature range (C) | -40 to 85 |
Power consumption (Typ) (mW) | 2.9 |
Analog voltage AVDD (Min) (V) | 2.7 |
Analog voltage AVDD (Max) (V) | 5.3 |
Digital supply (Min) (V) | 2.7 |
Digital supply (Max) (V) | 5.3 |
- Complete Front-End for Bridge Sensor
- Onboard PGA with Gain of 64 or 128
- Onboard Oscillator
- RMS Noise:
40nV at 10SPS (G = 128)
88nV at 80SPS (G = 128) - 18-Bit Noise-Free Resolution
- Selectable 10SPS or 80SPS Data Rates
- Simultaneous 50Hz and 60Hz Rejection at 10SPS
- External Voltage Reference up to 5V for Ratiometric Measurements
- Simple, Pin-Driven Control
- Two-Wire Serial Digital Interface
- Tiny 16-pin TSSOP Package
- Supply Range: 2.7V to 5.3V
- -40°C to +85°C Temperature Range
- APPLICATIONS
- Weigh Scales
- Strain Gauges
- Pressure Sensors
- Industrial Process Control
All trademarks are the property of their respective owners.
The ADS1230 is a precision 20-bit analog-to-digital converter (ADC). With an onboard low-noise programmable gain amplifier (PGA), onboard oscillator, and precision 20-bit delta-sigma ADC, the ADS1230 provides a complete front-end solution for bridge sensor applications including weigh scales, strain gauges, and pressure sensors.
The low-noise PGA has a gain of 64 or 128, supporting a full-scale differential input of ±39mV or ±19.5mV, respectively. The delta-sigma ADC has 20-bit effective resolution and is comprised of a 3rd-order modulator and 4th-order digital filter. Two data rates are supported: 10SPS (with both 50Hz and 60Hz rejection) and 80SPS. The ADS1230 can be clocked by the internal oscillator or an external clock source. Offset calibration is performed on-demand, and the ADS1230 can be put in a low-power standby mode or shut off completely in power-down mode.
All of the features of the ADS1230 are controlled by dedicated pins; there are no digital registers to program. Data are output over an easily-isolated serial interface that connects directly to the MSP430 and other microcontrollers.
The ADS1230 is available in a TSSOP-16 package and is specified from -40°C to +85°C.
