公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
16 位 250kSPS 6 通道同步采样 SAR ADC
Resolution (Bits) 16
Number of input channels 6
Sample rate (Max) (kSPS) 250
Interface type Byte-Wide, Parallel
Architecture SAR
Input type Pseudo-Differential
Multi-channel configuration Simultaneous Sampling
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 2.6
Input range (Min) (V) 0
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 190
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 88
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 4
Digital supply (Min) (V) 2.7
Digital supply (Max) (V) 5.5
  • Six Input Channels
  • Fully Differential Inputs
  • Six Independent 16-Bit ADCs
  • 4μs Total Throughput per Channel
  • Low Power:
    200mW in Normal Mode
    5mW in Nap Mode
    50μW in Power-Down Mode
  • TQFP-64 Package Package
  • APPLICATIONS
    • Motor Control
    • Multi-Axis Positioning Systems
    • 3-Phase Power Control
All trademarks are the property of their respective owners.
The ADS8365 includes six, 16-bit, 250kSPS analog-to-digital converters (ADCs) with six fully differential input channels grouped into three pairs for high-speed simultaneous signal acquisition. Inputs to the sample-and-hold amplifiers are fully differential and are maintained differential to the input of the ADC. This architecture provides excellent common-mode rejection of 80dB at 50kHz, which is important in high-noise environments.
The ADS8365 offers a flexible, high-speed parallel interface with a direct address mode, a cycle, and a FIFO mode. The output data for each channel is available as a 16-bit word.
