公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
14 位、155MSPS、1.1GHz 输入带宽模数转换器 (ADC)
Sample rate (Max) (MSPS) 155
Resolution (Bits) 14
Number of input channels 1
Interface type Parallel CMOS
Analog input BW (MHz) 1100
Features High Performance
Rating Catalog
Input range (Vp-p) 2
Power consumption (Typ) (mW) 967
Architecture Pipeline
SNR (dB) 72.3
ENOB (Bits) 11.6
SFDR (dB) 89.7
Operating temperature range (C) -40 to 85
Input buffer No
  • 1.1 GHz Full Power Bandwidth
  • Internal Sample-and-Hold Circuit
  • Low Power Consumption
  • Internal Precision 1.0V Reference
  • Single-Ended or Differential Clock Modes
  • Data Ready Output Clock
  • Clock Duty Cycle Stabilizer
  • Dual +3.3V and +1.8V Supply Operation
    (+/- 10%)
  • Power-Down Mode
  • Offset Binary or 2's Complement Output Data Format
  • 48-pin WQFN Package, (7x7x0.8mm, 0.5mm Pin-Pitch)
Key Specifications
  • Resolution: 14 Bits
  • Conversion Rate: 155 MSPS
  • SNR (fIN = 70 MHz): 71.3 dBFS (typ)
  • SFDR (fIN = 70 MHz): 87.0 dBFS (typ)
  • ENOB (fIN = 70 MHz): 11.5 bits (typ)
  • Full Power Bandwidth: 1.1 GHz (typ)
  • Power Consumption: 967 mW (typ)
All trademarks are the property of their respective owners.
The ADC14155 is a high-performance CMOS analog-to-digital converter capable of converting analog input signals into 14-bit digital words at rates up to 155 Mega Samples Per Second (MSPS). This converter uses a differential, pipelined architecture with digital error correction and an on-chip sample-and-hold circuit to minimize power consumption and the external component count, while providing excellent dynamic performance. A unique sample-and-hold stage yields a full-power bandwidth of 1.1 GHz. The ADC14155 operates from dual +3.3V and +1.8V power supplies and consumes 967 mW of power at 155 MSPS.
The separate +1.8V supply for the digital output interface allows lower power operation with reduced noise. A power-down feature reduces the power consumption to 5 mW with the clock input disabled, while still allowing fast wake-up time to full operation.
The differential inputs provide a full scale differential input swing equal to 2 times the reference voltage. A stable 1.0V internal voltage reference is provided, or the ADC14155 can be operated with an external reference.
The ADC14155 can be configured for either single-ended or differential operation. Clock mode (differential versus single-ended) and output data format (offset binary versus 2's complement) are pin-selectable. A duty cycle stabilizer maintains performance over a wide range of clock duty cycles.
The ADC14155 is available in a 48-lead WQFN package and operates over the industrial temperature range of ?40°C to +85°C.
