公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
13 位、210MSPS 模数转换器 (ADC)
Sample rate (Max) (MSPS) 210
Resolution (Bits) 13
Number of input channels 1
Interface type Parallel LVDS
Analog input BW (MHz) 500
Features High Performance
Rating Catalog
Input range (Vp-p) 2.2
Power consumption (Typ) (mW) 2250
Architecture Pipeline
SNR (dB) 69.8
ENOB (Bits) 11.4
SFDR (dB) 84
Operating temperature range (C) -40 to 85
Input buffer Yes
  • 13-Bit Resolution
  • 210 MSPS Sample Rate
  • SNR = 69 dBc at 100-MHz IF and 210 MSPS
  • SFDR = 76 dBc at 100-MHz IF and 210 MSPS
  • SNR = 68.1 dBc at 230-MHz IF and 210 MSPS
  • SFDR = 74 dBc at 230-MHz IF and 210 MSPS
  • 2.2 VPP Differential Input Voltage
  • Fully Buffered Analog Inputs
  • 5 V Analog Supply Voltage
  • LVDS Compatible Outputs
  • Total Power Dissipation: 2 W
  • Offset Binary Output Format
  • TQFP-80 PowerPAD? Package
  • Pin Compatible with the ADS5444
  • Industrial Temperature Range = -40°C to 85°C
  • RELATED PRODUCTS
    • ADS5424 - 14-bit, 105 MSPS ADC
    • ADS5423 - 14-bit, 80 MSPS ADC
    • ADS5444 - 13-bit, 250 MSPS ADC
  • APPLICATIONS
    • Test and Measurement
    • Software-Defined Radio
    • Multi-channel Basestation Receivers
    • Basestation Tx Digital Predistortion
    • Communications Instrumentation
PowerPAD is a trademark of Texas Instruments.
The ADS5440 is a 13-bit 210 MSPS analog-to-digital converter (ADC) that operates from a 5 V supply, while providing LVDS-compatible digital outputs from a 3.3 V supply. The ADS5440 input buffer isolates the internal switching of the onboard track and hold (T&H) from disturbing the signal source. An internal reference generator is also provided to further simplify the system design. The ADS5440 has outstanding low noise and linearity over input frequency.
The ADS5440 is available in an 80-pin TQFP PowerPAD? package. The ADS5440 is built on a state of the art Texas Instruments complementary bipolar process (BiCom3X) and is specified over the full industrial temperature range (-40°C to 85°C).
