公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
8 位、双路 1.5GSPS 或单路 3.0GSPS 模数转换器 (ADC)
Sample rate (Max) (MSPS) 1500, 3000
Resolution (Bits) 8
Number of input channels 2, 1
Interface type Parallel LVDS
Analog input BW (MHz) 1700
Features Ultra High Speed
Rating Catalog
Input range (Vp-p) 0.87
Power consumption (Typ) (mW) 1800
Architecture Folding Interpolating
SNR (dB) 47
ENOB (Bits) 7.4
SFDR (dB) 56
Operating temperature range (C) -40 to 85
Input buffer No
  • Internal Sample-and-Hold
  • Single +1.9V ±0.1V Operation
  • Choice of SDR or DDR Output Clocking
  • Interleave Mode for 2x Sample Rate
  • Multiple ADC Synchronization Capability
  • Ensured No Missing Codes
  • Serial Interface for Extended Control
  • Fine Adjustment of Input Full-Scale Range and Offset
  • Duty Cycle Corrected Sample Clock
Key Specifications
  • Resolution 8 Bits
  • Max Conversion Rate 1.5 GSPS (min)
  • Error Rate 10-18 (typ)
  • ENOB @ 748 MHz Input 7.25 Bits (typ)
  • DNL ±0.15 LSB (typ)
  • Power Consumption
    • Operating 1.8 W (typ)
    • Power Down Mode 3.5 mW (typ)
All trademarks are the property of their respective owners.
The ADC08D1500 is a dual, low power, high performance CMOS analog-to-digital converter that digitizes signals to 8 bits resolution at sample rates up to 1.7 GSPS. Consuming a typical 1.8 Watts at 1.5 GSPS from a single 1.9 Volt supply, this device is ensured to have no missing codes over the full operating temperature range. The unique folding and interpolating architecture, the fully differential comparator design, the innovative design of the internal sample-and-hold amplifier and the self-calibration scheme enable a very flat response of all dynamic parameters beyond Nyquist, producing a high 7.25 ENOB with a 748 MHz input signal and a 1.5 GHz sample rate while providing a 10-18 C.E.R. Output formatting is binary and the LVDS digital outputs are compatible with IEEE 1596.3-1996, with the exception of an adjustable common mode voltage between 0.8V and 1.2V.
Each converter has a 1:2 demultiplexer that feeds two LVDS buses and reduces the output data rate on each bus to half the sample rate. The two converters can be interleaved and used as a single 3 GSPS ADC.
The converter typically consumes less than 3.5 mW in the Power Down Mode and is available in a 128-lead, thermally enhanced exposed pad HLQFP and operates over the Industrial (-40°C ≤ TA ≤ +85°C) temperature range.
