Resolution (Bits) | 8 |
Number of input channels | 8 |
Sample rate (Max) (kSPS) | 200 |
Interface type | SPI, Microwire (Serial I/O) |
Architecture | SAR |
Input type | Single-Ended |
Multi-channel configuration | Multiplexed |
Rating | Catalog |
Reference mode | Supply |
Input range (Max) (V) | 5.25 |
Input range (Min) (V) | 0 |
Operating temperature range (C) | -40 to 105 |
Power consumption (Typ) (mW) | 0.9 |
Analog voltage AVDD (Min) (V) | 2.7 |
SNR (dB) | 49.5 |
Analog voltage AVDD (Max) (V) | 5.25 |
INL (Max) (+/-LSB) | 0.2 |
Digital supply (Min) (V) | 2.7 |
Digital supply (Max) (V) | 5.25 |
- Eight Input Channels
- Variable Power Management
- Independent Analog and Digital Supplies
- SPI/QSPI/MICROWIRE/DSP Compatible
- Packaged in 16-Lead TSSOP
Key Specifications
- Conversion Rate: 50 ksps to 200 ksps
- DNL (VA = VD = 2.7V to 5.25V): ±0.2 LSB (Max)
- INL (VA = VD = 2.7V to 5.25V): ±0.2 LSB (Max)
- Power Consumption
- 3V Supply: 0.9 mW (Typ)
- 5V Supply: 5.5 mw (Typ)
All trademarks are the property of their respective owners.
The ADC088S022 is a low-power, eight-channel CMOS 8-bit analog-to-digital converter specified for conversion throughput rates of 50 ksps to 200 ksps. The converter is based on a successive-approximation register architecture with an internal track-and-hold circuit. It can be configured to accept up to eight input signals at inputs IN0 through IN7.
The output serial data is straight binary and is compatible with several standards, such as SPI, QSPI, MICROWIRE, and many common DSP serial interfaces.
The ADC088S022 may be operated with independent analog and digital supplies. The analog supply (VA) can range from +2.7V to +5.25V, and the digital supply (VD) can range from +2.7V to VA. Normal power consumption using a +3V or +5V supply is 0.9 mW and 5.5 mW, respectively. The power-down feature reduces the power consumption to 0.03 μW using a +3V supply and 0.15 μW using a +5V supply.
The ADC088S022 is packaged in a 16-lead TSSOP package. Operation over the extended industrial temperature range of ?40°C to +105°C is ensured.
