公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
8 通道、50 ksps 至 200 ksps、12 位模数转换器
Resolution (Bits) 12
Number of input channels 8
Sample rate (Max) (kSPS) 200
Interface type SPI, Microwire (Serial I/O)
Architecture SAR
Input type Single-Ended
Multi-channel configuration Multiplexed
Rating Catalog
Reference mode Supply
Input range (Max) (V) 5.25
Input range (Min) (V) 0
Operating temperature range (C) -40 to 105
Power consumption (Typ) (mW) 1.2
Analog voltage AVDD (Min) (V) 2.7
SNR (dB) 73
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 1
Digital supply (Min) (V) 2.7
Digital supply (Max) (V) 5.25
  • Eight Input Channels
  • Variable Power Management
  • Independent Analog and Digital Supplies
  • SPI?/QSPI?/MICROWIRE/DSP Compatible
  • Packaged in 16-lead TSSOP
  • Conversion Rate: 50 ksps to 200ksps
  • DNL (VA = VD = 5 V): +1 / –0.7 LSB (Maximum)
  • INL (VA = VD = 5 V): ±1 LSB (Maximum)
  • Power Consumption
    • 3V Supply: 1.2 mW (Typical)
    • 5V Supply: 7.5 mW (Typical)
The ADC128S022 device is a low-power, eight-channel CMOS 12-bit analog-to-digital converter specified for conversion throughput rates of 50 ksps to 200 ksps. The converter is based on a successive-approximation register architecture with an internal track-and-hold circuit. It can be configured to accept up to eight input signals at inputs IN0 through IN7.
The output serial data is straight binary and is compatible with several standards, such as SPI, QSPI, MICROWIRE, and many common DSP serial interfaces.
The ADC128S022 may be operated with independent analog and digital supplies. The analog supply (VA) can range from 2.7 V to 5.25 V, and the digital supply (VD) can range from 2.7 V to VA. Normal power consumption using a 3-V or 5-V supply is 1.2 mW and 7.5 mW, respectively. The power-down feature reduces the power consumption to 0.06 μW using a 3-V supply and 0.25 μW using a 5-V supply.
The ADC128S022 is packaged in a 16-lead TSSOP package. Operation over the extended industrial temperature range of –40°C to +105°C is ensured.
