公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有 SPI 的汽车类 10 位、500kSPS、单通道 SAR ADC
Resolution (Bits) 10
Number of input channels 1
Sample rate (Max) (kSPS) 500
Interface type SPI, Microwire (Serial I/O)
Architecture SAR
Input type Single-Ended
Rating Automotive
Reference mode Supply
Input range (Max) (V) 5.25
Input range (Min) (V) 0
Features Small Size
Operating temperature range (C) -40 to 125
Power consumption (Typ) (mW) 2.7
Analog voltage AVDD (Min) (V) 2.7
SNR (dB) 61.6
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 0.7
Digital supply (Min) (V) 2.7
Digital supply (Max) (V) 5.25
  • Specified Over a Range of Sample Rates.
  • 6-lead WSON and SOT-23 Packages
  • Variable Power Management
  • Single Power Supply with 2.7V – 5.25V Range
  • SPI?/QSPI?/MICROWIRE/DSP Compatible
  • AECQ100 Grade 1 Qualified
The ADC101S051 is a low-power, single channel CMOS 10-bit analog-to-digital converter with a high-speed serial interface. Unlike the conventional practice of specifying performance at a single sample rate only, the ADC101S051 is fully specified over a sample rate range of 200 ksps to 500 ksps. The converter is based upon a successive-approximation register architecture with an internal track-and-hold circuit.
The output serial data is straight binary, and is compatible with several standards, such as SPI?, QSPI?, MICROWIRE, and many common DSP serial interfaces.
The ADC101S051 operates with a single supply that can range from +2.7V to +5.25V. Normal power consumption using a +3.6V or +5.25V supply is 2.7 mW and 9.7 mW, respectively. The power-down feature reduces the power consumption to as low as 2.6 μW using a +5.25V supply.
The ADC101S051 is packaged in 6-lead WSON and SOT-23 packages. Operation is specified over the temperature range of ?40°C to +85°C for the ADC101S051 and ?40°C to +125°C for the ADC101S051Q.
