Sample rate (Max) (MSPS) | 125 |
Resolution (Bits) | 14 |
Number of input channels | 1 |
Interface type | Parallel CMOS |
Analog input BW (MHz) | 750 |
Features | High Performance |
Rating | HiRel Enhanced Product |
Input range (Vp-p) | 2.3 |
Power consumption (Typ) (mW) | 780 |
Architecture | Pipeline |
SNR (dB) | 71.5 |
ENOB (Bits) | 11.3 |
SFDR (dB) | 84 |
Operating temperature range (C) | -55 to 125 |
Input buffer | No |
- 14-Bit Resolution
- 125-MSPS Sample Rate
- High Signal-to-Noise Ratio (SNR):
70.5 dBFS at 100 MHz fIN (TYP) - High Spurious-Free Dynamic Range (SFDR):
82 dBc at 100-MHz fIN (TYP) - 2.3-VPP Differential Input Voltage
- Internal Voltage Reference
- 3.3-V Single-Supply Voltage
- Analog Power Dissipation: 578 mW
- Total Power Dissipation: 780 mW
- Serial Programming Interface
- TQFP-64 PowerPAD? Package
- SUPPORTS DEFENSE, AEROSPACE,
AND MEDICAL APPLICATIONS- Controlled Baseline
- One Assembly/Test Site
- One Fabrication Site
- Available in Military (–55.C/125°C)
Temperature Range(1) - Extended Product Life Cycle
- Extended Product-Change Notification
- Product Traceability
- APPLICATIONS
- Wireless Communication
- Test and Measurement Instrumentation
- Single and Multichannel Digital Receivers
- Communication Instrumentation
- Radar, Infrared
- Video and Imaging
(1)Custom temperature ranges available.
The ADS5500-EP is a high-performance, 14-bit, 125 MSPS analog-to-digital converter (ADC). To provide a complete converter solution, it includes a high-bandwidth linear sample-and-hold stage (S&H) and internal reference. Designed for applications demanding the highest speed and highest dynamic performance in a small space, the ADS5500-EP has excellent power consumption of 780 mW at 3.3-V single-supply voltage. This allows an even higher system integration density. The provided internal reference simplifies system design requirements. A parallel CMOS-compatible output ensures seamless interfacing with common logic.
The ADS5500-EP is available in a 64-pin TQFP PowerPAD package and is specified over the full temperature range of ?55°C to +125°C.
