公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
两个 1 位、10MHz、2 阶 Δ-Σ 调制器
Resolution (Bits) 16
Number of input channels 2
Interface type Serial
Architecture Delta-Sigma Modulator
Input type Differential, Single-Ended
Multi-channel configuration Simultaneous Sampling
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 5
Input range (Min) (V) 0
Features Oscillator
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 59
Analog voltage AVDD (Min) (V) 4.5
SNR (dB) 88.9
Analog voltage AVDD (Max) (V) 5.5
INL (Max) (+/-LSB) 3
Digital supply (Min) (V) 2.7
Digital supply (Max) (V) 5.5
  • 16-Bit Resolution
  • 14-Bit Linearity
  • ±2.5V Input Range at 2.5V
  • Internal Reference Voltage: 2%
  • Gain Error: 0.5%
  • Two Independent Delta-Sigma Modulators
  • Two Input Reference Buffers
  • On-Chip 20MHz Oscillator
  • Selectable Internal or External Clock
  • Operating Temperature Range: -40°C to +85°C
  • QFN-24 (4x4) Package
  • APPLICATIONS
    • Motor Control
    • Current Measurement
    • Industrial Process Control
    • Instrumentation
    • Resolver
All trademarks are the property of their respective owners.
The ADS1205 is a two-channel, high-performance, delta-sigma () modulator with more than 98dB dynamic range, operating from a single +5V supply. The differential inputs are ideal for direct connection to transducers in an industrial environment. With the appropriate digital filter and modulator rate, the device can be used to achieve 16-bit analog-to-digital (A/D) conversion with no missing codes. Effective resolution of 14 bits can be obtained with a digital filter bandwidth of 40kHz at a modulator rate of 10MHz. The ADS1205 is designed for use in high-resolution measurement applications including current measurements, smart transmitters, industrial process control, and resolvers. It is available in a QFN-24 (4x4) package.
