公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
14 位、105MSPS 模数转换器 (ADC)
Sample rate (Max) (MSPS) 105
Resolution (Bits) 14
Number of input channels 1
Interface type Parallel CMOS
Analog input BW (MHz) 750
Features High Performance
Rating Catalog
Input range (Vp-p) 2.3
Power consumption (Typ) (mW) 710
Architecture Pipeline
SNR (dB) 73.6
ENOB (Bits) 11.7
SFDR (dB) 86
Operating temperature range (C) -40 to 85
Input buffer No
  • 14-Bit Resolution
  • 105MSPS Sample Rate
  • High SNR: 72dBFS at 100MHz fIN
  • High SFDR: 86dBc at 100MHz fIN
  • 2.3VPP Differential Input Voltage
  • Internal Voltage Reference
  • 3.3V Single-Supply Voltage
  • Analog Power Dissipation: 571mW
  • Serial Programming Interface
  • TQFP-64 PowerPAD? Package
  • Pin-Compatible With:
    • ADS5500 (14-Bit, 125MSPS)
    • ADS5542 (14-Bit, 80MSPS)
    • ADS5520 (12-Bit, 125MSPS)
    • ADS5521 (12-Bit, 105MSPS)
    • ADS5522 (12-Bit, 80MSPS)
  • Recommended Op Amps:
    • OPA695, OPA847, THS3202, THS3201, THS4503, THS4509, THS9001
  • APPLICATIONS
    • Wireless Communication
      • Communication Receivers
      • Base Station Infrastructure
    • Test and Measurement Instrumentation
    • Single and Multichannel Digital Receivers
    • Communication Instrumentation
      • Radar, Infrared
    • Video and Imaging
    • Medical Equipment
    • Military Equipment
PowerPAD is a trademark of Texas Instruments.
All other trademarks are the property of their respective owners.
The ADS5541 is a high-performance, 14-bit, 105MSPS analog-to-digital converter (ADC). To provide a complete converter solution, it includes a high-bandwidth linear sample-and-hold stage (S&H) and internal reference. Designed for applications demanding the highest speed and highest dynamic performance in a small space, the ADS5541 has excellent analog power dissipation of 571mW at 3.3V single-supply voltage. This allows an even higher system integration density. The provided internal reference simplifies system design requirements. The parallel CMOS compatible outputs ensure seamless interfacing with common logic.
The ADS5541 is available in a TQFP-64 PowerPAD package over the industrial temperature range.
