Sample rate (Max) (MSPS) | 80 |
Resolution (Bits) | 12 |
Number of input channels | 1 |
Interface type | Parallel CMOS |
Analog input BW (MHz) | 750 |
Features | Low Power |
Rating | Catalog |
Input range (Vp-p) | 2.3 |
Power consumption (Typ) (mW) | 660 |
Architecture | Pipeline |
SNR (dB) | 70.5 |
ENOB (Bits) | 11.3 |
SFDR (dB) | 87 |
Operating temperature range (C) | -40 to 85 |
Input buffer | No |
- 12-Bit Resolution
- 80 MSPS Sample Rate
- High SNR: 69.7 dBFS at 100 MHz fIN
- High SFDR: 83 dBc at 100 MHz fIN
- 2.3-VPP Differential Input Voltage
- Internal Voltage Reference
- 3.3-V Single-Supply Voltage
- Analog Power Dissipation: 541 mW
- Serial Programming Interface
- TQFP-64 PowerPAD? Package
- Recommended Op Amps:
OPA695, OPA847, THS3201, THS3202, THS4503, THS4509, THS9001 - APPLICATIONS
- Wireless Communication
- Communication Receivers
- Base Station Infrastructure
- Test and Measurement Instrumentation
- Single and Multichannel Digital Receivers
- Communication Instrumentation
- Radar, Infrared
- Video and Imaging
- Medical Equipment
PowerPAD is a trademark of Texas Instruments.
The ADS5522 is a high-performance, 12-bit, 80 MSPS analog-to-digital converter (ADC). To provide a complete converter solution, it includes a high-bandwidth linear sample-and-hold stage (S&H) and internal reference. Designed for applications demanding the highest speed and highest dynamic performance in little space, the ADS5522 has excellent power consumption of 541 mW at 3.3-V single-supply voltage. This allows an even higher system integration density. The provided internal reference simplifies system design requirements. Parallel CMOS-compatible output ensures seamless interfacing with common logic.
The ADS5522 is available in a 64-pin TQFP PowerPAD package over the industrial temperature range.
