公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有基准电压和伪单极性差分输入的 18 位 600KSPS 串行 ADC
Resolution (Bits) 18
Number of input channels 1
Sample rate (Max) (kSPS) 600
Interface type SPI
Architecture SAR
Input type Pseudo-Differential, Single-Ended
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 4.2
Input range (Min) (V) 0
Features Oscillator
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 115
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 91
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 4
Digital supply (Min) (V) 2.7
Digital supply (Max) (V) 5.25
  • 600-kHz Sample Rate
  • ±2 LSB Typ, ±4 LSB Max INL
  • 18-Bit NMC Ensured Over Temperature
  • SINAD 91 dB, SFDR 119 dB at fi = 1 kHz
  • High-Speed Serial Interface up to 40 MHz
  • Onboard Reference Buffer
  • Onboard 4.096-V Reference
  • Pseudo-Differential Input, 0 V to 4.2 V
  • Onboard Conversion Clock
  • Selectable Output Format, 2’s Complement or Straight Binary
  • Zero Latency
  • Wide Digital Supply
  • Low Power:
    • 115 mW at 600 kHz
    • 15 mW During Nap Mode
    • 10 μW During Power Down
  • 28-Pin 6 x 6 QFN Package
  • APPLICATIONS
    • Medical Instruments
    • Optical Networking
    • Transducer Interface
    • High Accuracy Data Acquisition Systems
    • Magnetometers
The ADS8380 is a high performance 18-bit, 600-kHz A/D converter with single-ended (pseudo-differential) input. The device includes an 18-bit capacitor-based SAR A/D converter with inherent sample and hold. The ADS8380 offers a high-speed CMOS serial interface with clock speeds up to 40 MHz.
The ADS8380 is available in a 28 lead 6 × 6 QFN package and is characterized over the industrial ?40°C to 85°C temperature range.
