Resolution (Bits) | 18 |
Number of input channels | 1 |
Sample rate (Max) (kSPS) | 600 |
Interface type | SPI |
Architecture | SAR |
Input type | Differential |
Rating | Catalog |
Reference mode | Ext, Int |
Input range (Max) (V) | 4.2 |
Input range (Min) (V) | 0 |
Features | Oscillator |
Operating temperature range (C) | -40 to 85 |
Power consumption (Typ) (mW) | 115 |
Analog voltage AVDD (Min) (V) | 4.75 |
SNR (dB) | 96 |
Analog voltage AVDD (Max) (V) | 5.25 |
INL (Max) (+/-LSB) | 3 |
Digital supply (Min) (V) | 2.7 |
Digital supply (Max) (V) | 5.25 |
- 600-kHz Sample Rate
- ±1.25 LSB Typ, ±3 LSB Max INL
- 18-Bit NMC Ensured Over Temperature
- SINAD 96 dB, SFDR 120 dB at fi = 1 kHz
- High-Speed Serial Interface up to 40 MHz
- Onboard Reference Buffer
- Onboard 4.096-V Reference
- Pseudo-Bipolar Input, up to ±4.2 V
- Onboard Conversion Clock
- Zero Latency
- Wide Digital Supply
- Low Power
- 115 mW at 600 kHz
- 15 mW During Nap Mode
- 10 μW During Power Down
- 28-Pin 6 × 6 QFN Package
- APPLICATIONS
- Medical Instruments
- Optical Networking
- Transducer Interface
- High Accuracy Data Acquisition Systems
- Magnetometers
The ADS8382 is a high performance 18-bit, 600-kHz A/D converter with fully differential, pseudo-bipolar input. The device includes an 18-bit capacitor-based SAR A/D converter with inherent sample and hold. The ADS8382 offers a high-speed CMOS serial interface with clock speeds up to 40 MHz.
The ADS8382 is available in a 28 lead 6 × 6 QFN package and is characterized over the industrial ?40°C to 85°C temperature range.
