Resolution (Bits) | 8 |
Number of input channels | 8 |
Sample rate (Max) (kSPS) | 70 |
Interface type | I2C |
Architecture | SAR |
Input type | Pseudo-Differential, Single-Ended |
Multi-channel configuration | Multiplexed |
Rating | Catalog |
Reference mode | Ext, Int |
Input range (Max) (V) | 5.25 |
Input range (Min) (V) | 0 |
Operating temperature range (C) | -40 to 85 |
Power consumption (Typ) (mW) | 0.75 |
Analog voltage AVDD (Min) (V) | 2.7 |
SNR (dB) | 50 |
Analog voltage AVDD (Max) (V) | 5.25 |
INL (Max) (+/-LSB) | 0.5 |
Digital supply (Min) (V) | 2.7 |
Digital supply (Max) (V) | 5.25 |
- 70kHz SAMPLING RATE
- ±0.5LSB INL/DNL
- 8 BITS NO MISSING CODES
- 4 DIFFERENTIAL/8 SINGLE-ENDED INPUTS
- 2.7V TO 5V OPERATION
- BUILT-IN 2.5V REFERENCE/BUFFER
- SUPPORTS ALL THREE I2C MODES:
Standard, Fast, and High-Speed - LOW POWER:
180μW (Standard Mode)
300μW (Fast Mode)
675μW (High-Speed Mode) - DIRECT PIN COMPATIBLE WITH ADS7828
- TSSOP-16 PACKAGE
The ADS7830 is a single-supply, low-power, 8-bit data acquisition device that features a serial I2C interface and an 8-channel multiplexer. The Analog-to-Digital (A/D) converter features a sample-and-hold amplifier and internal, asynchronous clock. The combination of an I2C serial, 2-wire interface and micropower consumption makes the ADS7830 ideal for applications requiring the A/D converter to be close to the input source in remote locations and for applications requiring isolation. The ADS7830 is available in a TSSOP-16 package.
