公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有 P8/P16 并行输出、内部时钟和内部基准的 16 位 2MSPS ADC
Resolution (Bits) 16
Number of input channels 1
Sample rate (Max) (kSPS) 2000
Interface type Byte-Wide, Parallel
Architecture SAR
Input type Pseudo-Differential, Single-Ended
Rating Catalog
Reference mode Ext, Int
Input range (Max) (V) 4.1
Input range (Min) (V) 0
Features Oscillator
Operating temperature range (C) -40 to 85
Power consumption (Typ) (mW) 155
Analog voltage AVDD (Min) (V) 4.75
SNR (dB) 86
Analog voltage AVDD (Max) (V) 5.25
INL (Max) (+/-LSB) 2.5
Digital supply (Min) (V) 2.7
Digital supply (Max) (V) 5.25
  • 2-MHz Sample Rate
  • 16-Bit NMC Ensured Over Temperature
  • Zero Latency
  • Unipolar Single-Ended Input Range: 0 V to Vref
  • Onboard Reference
  • Onboard Reference Buffer
  • High-Speed Parallel Interface
  • Power Dissipation: 175 mW at 2 MHz Typ
  • Wide Digital Supply
  • 8-/16-Bit Bus Transfer
  • 48-Pin TQFP Package
  • ESD Sensitive - HBM Capability of 500 V, 1000 V at All input Pins
  • APPLICATIONS
    • DWDM
    • Instrumentation
    • High-Speed, High-Resolution, Zero Latency Data Acquisition Systems
    • Transducer Interface
    • Medical Instruments
    • Communication
The ADS8411 is a 16-bit, 2 MHz A/D converter with an internal 4.096-V reference. The device includes a 16-bit capacitor-based SAR A/D converter with inherent sample and hold. The ADS8411 offers a full 16-bit interface and an 8-bit option where data is read using two 8-bit read cycles.
The ADS8411 has a unipolar single-ended input. It is available in a 48-lead TQFP package and is characterized over the industrial ?40°C to 85°C temperature range.
